PrusaSlicer disappeared and cannot re-install it
Hi, I am having a very strange issue. My slicer, somehow, disappeared without uninstalling it. Everything was removed apart from the appdata. Now, when I'm trying to reinstall it, I'm having an issue with permissions:
"The installer has insufficient privileges to access this directory: C:\ProgramData\Microsoft\Windows\Start Menu\Prusa3D. The installation cannot continue. Log on as administrator or contact your system administrator"
This is my personal PC, I'm the administrator, and have gone through all the security properties to make sure that everything is in order. Has anyone encountered such a problem? Any suggestions? Running out of ideas here.
RE: PrusaSlicer disappeared and cannot re-install it
Try the following.
Select the Prusa3d.exe file.
Press the right mouse button and select the option Run as administrator.
I have the same thing. Prusa just disappeared. I used it the day before yesterday and today it's gone. what's happening? Does anyone have an Idea?
