PrusaSlicer crashes when initializing Physical Printer
shep
 shep
(@shep-2)
In Debian Trixie with the Debian Build of PrusaSlicer 2.9.2, and a Sovol SV06Ace/Klipper, PrusaSlicer crashes shortly after the initialization progress bar starts.
I've assigned a static IP to the printer which I can ping.  I can also open klipper in Firefox-esr at static-ip:80 and in webkitbased vimb.  I've tried both Octoprint and Klipper via moonraker in PrusaSlicer Physical printer and both crash.  The printer verifies in the PrusaSlicer interface (?successful ping).
Is this a known issue and are there any configuration options I can set as a workaround?
Thanks
Veröffentlicht : 25/12/2025 5:32 pm
Walter Layher
(@walter-layher)
RE: PrusaSlicer crashes when initializing Physical Printer
Did you try to start PrusaSlicer via a terminal to see the error messages? Perhaps you can then google for those?
Veröffentlicht : 25/12/2025 5:39 pm
You should check the PS github for issues.  For example https://github.com/prusa3d/PrusaSlicer/issues/13835 may have some things you could try.  There are several issues if you care to use search (remember to look at both Open and closed ones).
Veröffentlicht : 25/12/2025 5:46 pm
shep
 shep
(@shep-2)
[2025-12-25 10:00:53.027513] [0x00007efcc01e04c0] [error]   UserAccount: Failed to read token - no datafile found.
(prusa-slicer:28566): Gtk-CRITICAL **: 10:00:53.216: gtk_distribute_natural_allocation: assertion 'extra_space >= 0' failed
10:00:53 AM: Debug: window wxTreeCtrl@0x560b59434c10 ("treeCtrl") lost focus even though it didn't have it
I did not set up a Local CA file - I had the impression it was an option. I have no idea what the Gtk-CRITICAL error is that follows the "read token" warning.
There is an open issue on github:
https://github.com/prusa3d/PrusaSlicer/issues/14999
Diese r Beitrag wurde geändert Vor 4 months 2 mal von shep
Veröffentlicht : 25/12/2025 6:06 pm
_KaszpiR_
(@_kaszpir_)
/usr/bin/flatpak run --branch=stable --arch=x86_64 --command=entrypoint --file-forwarding com.prusa3d.PrusaSlicer --loglevel 5 > prusaslicer.loglevel5.stdout.log 2>prusaslicer.loglevel.stderr.log
this way you can have stdout/stderr logs with trace enabled written to files.
Generally the core part is:
Veröffentlicht : 26/12/2025 1:13 pm
