PrusaSlicer crashes on opening
MikeW
(@mikew)
Hello, I wonder if anyone could help.
Since I had a major Windows update, I have not been able to use PrusaSlicer. It starts to open, and then I get an error message stating that it is terminating. When I click OK on this message I the get the below error message:
I have tried uninstalling and re-installing but this still keeps happening.
I would appreciate any ideas.
Thanks
Publié : 18/07/2021 3:04 pm
Baklin
(@baklin)
title
Could this be a permissions problem? Have you tried run PrusaSlicer as admin? (right click and "run as administrator")
Publié : 18/07/2021 3:28 pm
NickR
(@nickr)
RE: I'm having the same problem
I have the same problem as @amdwkarai1.  I have tried running the program as administrator and still get the same issue.  It opens, but as soon as I click anything, it says "Not Responding"
For what it's worth here is what I'm running:
Windows 10 Pro, Version 10.0.19042 Build 19042
PrusaSlicer 2.3.1+win64
All of my drivers, etc. are up to date.
Ce message a été modifié il y a 5 years par NickR
Publié : 18/07/2021 8:27 pm
MikeW
(@mikew)
thanks
Thanks @Baklin, I gave that a try, but it did not work.
Publié : 20/07/2021 12:22 pm
MikeW
(@mikew)
I found a solution
I finally managed to get it to work. I deleted all the files in the Cache (...Appdata\Roaming\PrusaSlicer\cache) and then restarted the program and it seems to be working now.
Publié : 20/07/2021 12:24 pm
