PrusaSlicer craches when setting bed size to 3000x2000mm
jonas-3
(@jonas-3)
And why would I want to this you might ask? Well thats because I have a big printer (extruder mounted to a robot)
What happens is that it simply craches without warning.
Does anybody have an explanation for this?
Opublikowany : 03/01/2020 11:58 am
RE: PrusaSlicer craches when setting bed size to 3000x2000mm
Any error message or dump when it crashes?
Opublikowany : 03/01/2020 3:05 pm
jonas-3
(@jonas-3)
Posted by: @bobstro
No nothing at all. It just shuts down a few seconds after I press ok
Opublikowany : 03/01/2020 3:14 pm
Posted by: @jonas-3
If you think it's a bug, you should open an issue on the PrusaSlicer Github page so the developers can give it a look. Be prepared to provide some meaningful information though. Your OS, version, hardware configuration (incl. graphics) and at least the version of PrusaSlicer you're using are needed to even start to guess at what the problem might be.
Opublikowany : 03/01/2020 4:19 pm
Sembazuru
(@sembazuru)
I would also assume that the devs would want your printer profile. In fact, if I was submitting this bug I'd attach the .3mf project file that is confirmed to crash (as this will include all three profiles being used and the 3D object). If the crash you are experiencing is happening on a proprietary object, create or find a freely distributable object that shows the same issue and submit that.
See my (limited) designs on:
Opublikowany : 04/01/2020 5:48 pm
jonas-3
(@jonas-3)
Thank you all. I will open an issue on github
Opublikowany : 09/01/2020 12:43 pm
