PrusaSlicer - Change flow control limited by Layer Height/Line Width ratio
Good morning,
I want to make a print with a layer height of 0.4mm and line width of 2.5mm
However, the slicer limits the flow and therefore the line width which instead of being 2.5mm comes out to 2mm
To find my correct line width the only parameter (that I found) is to increase the layer height to a minimum of 0.6mm
For aesthetic reasons, I really want to stay at a max layer height of 0.4mm, but I would like to have a line width of 2.5mm see for test 3mm How can I disable or change this limiter?
Sincerely
"message translated by google translate"
Veröffentlicht : 23/10/2024 8:24 am
What size nozzles are you using? Which hotend? You might manage this with a 0.8mm nozzle but 1.0mm would be easier.
Veröffentlicht : 24/10/2024 6:27 am
