PrusaSlicer and Ender 3 Pro
I just started using PrusaSlicer (was using Cura before) and I would like to set the bed size to 235x235 instead of the 220x220 but I cannot find how to do this.
PrusaSlicer version: 2.3.1
RE: PrusaSlicer and Ender 3 Pro
Make sure you are in at least Advanced mode or the settings you need wont be visible.
Select Printer Settings>General. At the top there is a section called Size and coordinates. Click the Button for Set Bed shape. That pops up a form allowing you to set the size, shape , origin etc for your bed. Its also where you can load a texture for the bed or a stl for the printer.
Be aware that once you have modified any settings you will need to save the Profile as a custom one as PS doesn't allow you to save over any defaults. So please be sure to select the new named profile when slicing for the settings to be in effect.
@neophyl
Got it, thank you for your help
