PrusaSlicer 2.8.0+MacOS arm64 sequential printing broken?
akliouev
(@akliouev)
Mitglied
Hi!
Just auto-upgraded to 2.8.0 on my trusty Mac and it work find, exept that the sequential printing of objects apperas to be broken
If I enable the "complete individual objects" option, the slicer immediately claims "some objects are too tall and cannot be printed without extruder collisions", no matter where I put the objects on the build plate. The objects in question do fit into a cylinder of about 25mm in diameter and about 50 mm tall and I need 4 of those on the build plate and prior to the upgrade it was working just fine.
Is there some extra steps required for sequential printing in 2.8.0 or it's a bug of some sorts?
Veröffentlicht : 30/07/2024 7:51 am
RE: PrusaSlicer 2.8.0+MacOS arm64 sequential printing broken?
If you want to check if something has been reported as a issue then you go to
https://github.com/prusa3d/PrusaSlicer/issues?q=is%3Aissue+is%3Aopen+sort%3Aupdated-desc
Veröffentlicht : 30/07/2024 10:01 am
