PrusaSlicer-2.8.0 libwebkit2gtk-4.0.so.37: cannot open shared object file
Rikky0
(@rikky0)
Membre
After upgrading Prusaslicer I get the following error
PrusaSlicer-2.8.0 /tmp/.mount_PrusaSZR9Gse/usr/bin/bin/prusa-slicer: error while
I'm running sklackware 15.0 the 2.7.4 version worked fine
I looked for the libwebkit2gtk-4.0.so.37 and indeed it is not on my system
Now my question is, do more people suffer from this? and should I create this as
Richard
Publié : 27/06/2024 7:09 pm
JimB
 JimB
(@jimb)
RE: PrusaSlicer-2.8.0 libwebkit2gtk-4.0.so.37: cannot open shared object file
I just tried it and got the same error on Ubuntu 24.04.
Publié : 27/06/2024 9:38 pm
JimB
 JimB
(@jimb)
https://github.com/prusa3d/PrusaSlicer/issues/12931
Publié : 27/06/2024 9:42 pm
_KaszpiR_
(@_kaszpir_)
It's stated on the release page:
We now provide two separate AppImages. One depends on the old WebKit, the other one is built on Ubuntu 24.04 and links to the new WebKit. If you run Ubuntu 20.04, Fedora 40 or another very recent distribution, you should download the "Ubuntu-20-04" AppImage. The other one will not work for you.
Publié : 28/06/2024 7:13 am
Michiel
(@michiel-2)
Feedback to the team it might be good to rethink the filename for the other version-name , it doesn´t match other current up2date users if they need a appimage with ubuntu in the name?
second question : why push the incorrect image as standard to users as it will not work for all users  maybe the release page instead of a not working file smart?
Publié : 28/06/2024 4:03 pm
There's no ARM image either - 2.7.4 does run on Raspberry Pi but only in command-line mode - I was hoping that 2.8 would remedy this.  The autodownloader just fetches the x86 builds.
Publié : 29/06/2024 4:26 pm
Punished Brains
(@punished-brains)
It's a problem on Fedora as well, neither of the releases actually work. The Ubuntu version simply gives this error:
/tmp/.mount_PrusaSpcIgLB/usr/bin/bin/prusa-slicer: error while loading shared libraries: libwebkit2gtk-4.1.so.0: cannot open shared object file: No such file or directory
Publié : 12/07/2024 1:30 pm
Emil Perhinschi
(@emil-perhinschi)
Membre
Download from here https://github.com/prusa3d/PrusaSlicer/releases , pick the file ending in "Ubuntu-24-04.AppImage ".
Yes, annoying, but considering that my Mk3s survived a 500 km trip in a truck while sitting upside down in a cardboard box I tend to be forgiving :-).
Publié : 12/09/2024 12:25 pm
Muramasa
(@muramasa)
Membre
For those that end up here from google. Running Kubuntu or Ubuntu studio.
sudo apt install libwebkit2gtk-4.1-0 will allow you to run the the newer distro version.
Publié : 31/10/2024 7:24 am
