PrusaSlicer 2.7.4 MacOS output changes directory randomly.
tmorris9
(@tmorris9)
So, I keep my STL files and GCODE in 2 separate directories, has never been an issue and when I select Export GCODE it's always gone to the correct directory until the last time I updated. Now it will randomly switch to the loading directory (where I loaded an STL from) instead and it's causing a mess.
I checked and "Remember output directory" is set to on. I even turned it off, quite the program, reloaded and turned it back on but it's still doing it. Now, it does not do it every single time but rather 1/5 times, I tend to work fast and so I often don't notice until I go to transfer the GCODE into OctoPrint and see it's missing.
So, not sure how to put this in as a possible bug or if they maybe already know about it but searching online for the symptom really does not return anything useful. Also don't know if this is a Mac only issue or what.
Napsal : 02/06/2024 1:38 am
