PrusaSlicer 2.7.3 ignores filament extrusion multiplier value changes
KlinWer
(@klinwer)
Hello,
I am not able to change the filament extrusion multiplier value to 0,85. The first layer and the infill looks always the same, like a default value of 1,0.
Printer model is a MK4S with firmware 6.1.3.
Could you please check?
Publié : 29/11/2024 4:16 pm
3Delight
(@3delight)
Modérateur Moderator
RE: PrusaSlicer 2.7.3 ignores filament extrusion multiplier value changes
The latest version of PrusaSlicer is 2.8.1 so first I would recommend upgrading to that to ensure that you (much newer) printer is supported fully, and secondly have you got Expert mode switched on as some settings can only be changed in expert mode?
Publié : 29/11/2024 4:26 pm
KlinWer
(@klinwer)
RE: PrusaSlicer 2.8.1 ignores filament extrusion multiplier value changes
Thanks for the fast reply.
I messed up the versions. I already use version 2.8.1 and switched to expert mode.
Publié : 29/11/2024 5:03 pm
KlinWer
(@klinwer)
In the meantime I did an update to 2.9.0-alpha 1 with the same result. The filament extrusion multiplier value is ignored.
Publié : 29/11/2024 7:01 pm
KlinWer
(@klinwer)
Issue is solved now. Finally it was an issue with the MK4S upgrade kit. I had to  tighten the screws on the Idler-swivel assembly with two additional turns. Now it is working as expected.
Publié : 03/12/2024 9:59 am
1 personnes ont aimé
