PrusaSlicer 2.6.0-beta1 is out
Walter Layher
(@walter-layher)
Get it here.
Publié : 13/05/2023 9:13 pm
Ruud
 Ruud
(@ruud-3)
RE: PrusaSlicer 2.6.0-beta1 is out
Unable to select run as program in properties. So the slicer can no longer run independently without a utility. I use lunix mint 21.1 as operating system. How do i solve this?
Publié : 14/05/2023 6:04 am
Walter Layher
(@walter-layher)
I am on debian. I used git and compiled it as per the instructions on github for compiling on linux. Same result as the versions before.
But I also use the AppImages for the stable versions to have several versions of PS at my disposal. I would expect that this AppImage runs. That is the type I downloaded for the stable versions. To be sure I just tested the AppImage in the link. It starts without a problem. After downloading the AppImage you have to do a "chmod +x <filename>" on it to make it executable.
Publié : 14/05/2023 6:24 am
Hov3Dskou
(@hov3dskou)
When selecting Configuration Wizard the slicer closes down.. 😣
(Win64)
Ce message a été modifié il y a 3 years par Hov3Dskou
Ruud
 Ruud
(@ruud-3)
Thanks for the solution Walter. Now PS starts again as before. Problem solved.
Publié : 14/05/2023 7:21 am
Walter Layher
(@walter-layher)
The same happens on debian linux. Well, don't do that then (Linus Torvalds). 🙂
As a workaround you could configure your printer with an older version of PS and then use it with the newer version. Existing profiles are imported/converted on upgrade.
Publié : 14/05/2023 3:00 pm
