PrusaSlicer 2.5. issue: Chyba při nahrávání do tiskového serveru:
[Risolto] PrusaSlicer 2.5. issue: Chyba při nahrávání do tiskového serveru:
Miloslav Balcar
(@miloslav-balcar)
After installation 2.5.0, is no more possible to send gcode to Octoprint. API key is OK and the connection test is OK too. Any suggestions?
Best Answer by JimB:
https://forum.prusa3d.com/forum/prusaslicer/2-5-0-seems-reluctant-to-connect-to-my-octoprint/ and https://github.com/prusa3d/PrusaSlicer/issues/7716 both suggest added "https://" to the start of the hostname/ip/url field in the physical printer config.  Although I don't have that on mine and it works.  But maybe it depends on the OS running the slicer.
Postato : 15/02/2023 6:05 pm
JimB
 JimB
(@jimb)
RE: PrusaSlicer 2.5. issue: Chyba při nahrávání do tiskového serveru:
Postato : 15/02/2023 9:11 pm
Miloslav Balcar
(@miloslav-balcar)
Thank you, it solved my issue.
Postato : 15/02/2023 9:35 pm
