PrusaSlicer 2.5. issue: Chyba při nahrávání do tiskového serveru:
After installation 2.5.0, is no more possible to send gcode to Octoprint. API key is OK and the connection test is OK too. Any suggestions?
Best Answer by JimB:
https://forum.prusa3d.com/forum/prusaslicer/2-5-0-seems-reluctant-to-connect-to-my-octoprint/ and https://github.com/prusa3d/PrusaSlicer/issues/7716 both suggest added "https://" to the start of the hostname/ip/url field in the physical printer config. Although I don't have that on mine and it works. But maybe it depends on the OS running the slicer.
RE: PrusaSlicer 2.5. issue: Chyba při nahrávání do tiskového serveru:
Thank you, it solved my issue.
