PrusaSlicer 2.5.2
Same Old Shane
(@same-old-shane)
Member Admin
PrusaSlicer 2.5.2
Summary
​This is the final release of PrusaSlicer 2.5.2. This release is functionally equivalent to 2.5.1, the only difference is that it contains profiles for Original Prusa MK4 printer.
It does NOT contain Organic supports, the improved Cut tool, and other features introduced in PrusaSlicer 2.6.x series. These are currently only available in 2.6.0 prerelease versions (the most recent currently being 2.6.0-alpha5).
To download direct you can visit our Prusa Slicer website or github
www.prusa3d.com/page/prusaslicer_424/
https://github.com/prusa3d/PrusaSlicer/releases/tag/version_2.5.2
Shane (AKA FromPrusa)
Opublikowany : 30/03/2023 1:51 pm
Ray Trainman
(@ray-trainman)
PrusaSlicer 2.5.2 Download Error
Tride to download 2.5.2  from "github"  and when i try to install the new download I get the following error:
"error parsing prusaslicer config file, it is probably corrupted. try to manually delete the file to recover from error. your user profile will not be affected"
Opublikowany : 11/05/2023 5:44 pm
Alireza Toghraee
(@alireza-toghraee)
RE: PrusaSlicer 2.5.2
Hello
I have problem with lunching PrusaSlicer 2.5.2. I have installed that for Windows  but when I click, The program window shows up with the error message of "Unhandled unknown exception; terminating the application" . And when I click on that or close the error , the PrucaSlicer also closes. Any idea or help on this issue?
Thanks
Opublikowany : 02/06/2023 6:29 pm
Walter Layher
(@walter-layher)
Perhaps the same error as in this thread?
Opublikowany : 02/06/2023 6:38 pm
1 ludzie polubili
Alireza Toghraee
(@alireza-toghraee)
Yes, it seems the same error!
Opublikowany : 03/06/2023 1:05 am
