PrusaSlicer (2.4): Resin profiles for SL1S
gjw
 gjw
(@gjw)
Hello, newbie here. If I try to add a resin profile (say, Siraya Tech Fast Grey) to PrusaSlicer 2.4, I can see it in the Config Assistant and activate it there, but it's being shown as incompatible with SL1S ("...materials marked with * are not compatible with the installed printer") but they show to be compatible with SL1. How do I best go about getting the above resin profile added?
Thanks much!
g
Best Answer by Neophyl:
Caveat - I don't have a resin printer. however I just installed one to check the settings are like for a FFF printer, they are.
On your material settings tab theres a section called dependencies.  Must be in expert mode to see all the settings though.  In there will probably be a  compatible printers listing and compatible profiles.  You need to edit those to make them compatible for the printer you have.  Usually deleting them would make them compatible for all (most).
That's the 'old' way of limiting profiles though but still used in conjunction with the 'new' way which is vendor profiles.  If the vendor space is also locking it out then on the same page there is a  "Detach from system preset" button.  Activating that will unlink it.
Once you have it all edited you will need to save it as something with a unique name (not matching any of the system presets) as you cant permanently save over those.
Well you can sort of, by editing the behind the scenes .ini files but the next time you update the profiles your changes would be over written so its best to just save as a custom profile as that way its safe.
Also once you have it done you can always use File>Export>Export Config Bundle which will save a copy of any custom profiles to disk.  You can then restore those at a later point, like say of you want them on a new computer or you need to reinstall for some reason.
Opublikowany : 07/02/2022 8:49 pm
RE: PrusaSlicer (2.4): Resin profiles for SL1S
Opublikowany : 07/02/2022 9:42 pm
1 ludzie polubili
gjw
 gjw
(@gjw)
Thank you much for this useful&helpful response - worked for me.
Opublikowany : 08/02/2022 8:48 am
