Prusaslicer 2.4.2 won't open any STL or 3MF file
Jiheffe
(@jiheffe)
Prusaslicer on MacOS Monterey 12.3.1 on iMac Retina 5K, 27-inch, Late 2015, Intel based.
Problems started when I upgraded to 2.4.1. Whenever I try to open an STL of 3MF file, I get this message "Prusaslicer has encountered an error - Loading of a model failed".
I somehow managed to get it working again, but I do not remember how. I just know I went through uninstalling and reinstalling the whole thing, which lots of trouble to find all my saved prests...
Now just went from 2.4.1 to 2.4.2 and here we go again 😟  I can't load any file into PrusaSlicer...
I'd like to avoid going to all that fiddling again...
Any ideas... No one else had the same problem ?
Opublikowany : 06/05/2022 1:18 pm
Jiheffe
(@jiheffe)
RE: Prusaslicer 2.4.2 won't open any STL or 3MF file
Problem solved. My files are on Dropbox, and are removed locally when not used for some time.Before I can open them in PrusaSlicer, I need to manually make them available offline. This seems to be a change in Dropbox behaviour.
Opublikowany : 06/05/2022 2:47 pm
GerryPB
(@gerrypb)
I just started getting this error message. My issue is not related to drop box. If anyone has ideas how to solve it I would appreciate. I will keep trying to troubleshoot the best I can and will update if I can figure it out.
Opublikowany : 28/07/2024 5:47 pm
GerryPB
(@gerrypb)
FYI, I solved the cause for my case. It was a USB port hardware problem. Using a different USB port resolved the issue. Fusion 360 was on a different computer than PrusaSlicer. When I went to transfer the .stl or .3mf I guess the file was corrupted even though it looked like it transferred and it was the correct size.
Opublikowany : 30/07/2024 1:26 am
