PrusaSlicer 2.3 won't open in Windows 10
PrusaSlicer stopped working in Windows 10. I get a short spin when double-clicking the icon (or any other method of opening an application) and then nothing. I checked Task Manager and it doesn't show up there at all... nothing. I've tried uninstalling and re-installing and that doesn't fix the problem.
Opublikowany : 14/04/2021 10:26 pm
RE: PrusaSlicer 2.3 won't open in Windows 10
You are not the only one. However the cause is unknown at the moment https://github.com/prusa3d/PrusaSlicer/issues/5518
Try checking the windows error logs and also try the steps about starting from the command line with the error logging switch. I'm sure the devs over on github would love some more input as they haven't been able to duplicate the issue which makes fixing it problematic.
Opublikowany : 15/04/2021 6:35 am
