PrusaSlicer 2.3 Problems with the maximum distance on the Z axis
georgegherasim
(@georgegherasim)
Hello,
My name is George and until recently I used PrusaSlicer 2.2.0 on the printer I built myself, the print dimensions being x-1200 mm, y-1200 mm, z-1800 mm. But since I downloaded the new version 2.3 I discovered that I can't use it anymore, I can't set the race to Z higher than 1200, can you help me with this problem, or will I have to go back to 2.2.0?
Publié : 07/04/2021 2:24 pm
RE: PrusaSlicer 2.3 Problems with the maximum distance on the Z axis
There’s a limit to the maximum size now.  If I recall correctly it was due to some math limit in one or more of the functions. I can’t recall what the max is but I think it was around d 1200. So yes you will have to go back to 2.2 for the moment if you need bigger. I’d go on GitHub and add your vote to the issue about expanding the maximum size.
The relevant issue is https://github.com/prusa3d/PrusaSlicer/issues/6072.
Publié : 07/04/2021 3:16 pm
