PrusaSlicer 2.3 Crashing and Freezing.
Blakmajika
(@blakmajika)
Recently, my PrusaSlicer has been freezing, crashing, or both the moment I try to open the software. Sometimes it takes about 15 seconds or it crashes when I open the import file directories. After a few dozen tries I was able to get only a single stable time where I could actually slice a file. My drivers are updated and I am using Windows 10 with an AMD 5700XT card. I had similar issues with PrusaSlicer 2.2 but it more or less fixed itself when I manually opened up pronterface first, but ever since switching to 2.3 that solution doesn't work anymore.
Napsal : 08/03/2021 11:56 pm
towlerg
(@towlerg)
RE: PrusaSlicer 2.3 Crashing and Freezing.
There are a couple of posts (search is really bad on the board, try site search in google) with similar problems. At least one of these was tracked down to video drivers.
FWIW I use built-in UHD 630 Intel graphics on Win10, dead solid even slicing dodgy STL's. Perhaps your motherboard has built-in graphics that you can try?
Napsal : 09/03/2021 11:22 am
Blakmajika
(@blakmajika)
I figured out the issue, something was wrong with the prusa slicer drivers and I had to manually uninstall them. At the moment it seems fine, but if any issues return I'll bring it up here again.
Napsal : 09/03/2021 2:08 pm
towlerg
(@towlerg)
I don't understand "something was wrong with the prusa slicer drivers", I may be wrong but I didn't think Prusaslicer had any drivers.
This post was modified před 5 years by towlerg
Napsal : 10/03/2021 9:58 am
