PrusaSlicer 2.3 Beta Octoprint connection
Bob the Maker
(@bob-the-maker)
I am having trouble connecting to Octoprint. I have added a physical printer but it will not find the server in network search. I have tried adding the IP address and API info but fails to connect. Is anyone else having this problem?
Windows 10
Octoprint 1.5
Opublikowany : 02/12/2020 2:08 pm
aln.perez
(@aln-perez)
RE: PrusaSlicer 2.3 Beta Octoprint connection
Click on printers parameters... Now IP server is moved here.
MK3S + MMU2 migrée vers une MK4 +MMU3 , puis vers MK4S MMU3, puis upgrade vers Core One, Elegoo Mars, bricole sur Home assistant, arduino, 8266, Esp32, kicad, Freecad et Fusion 360
Opublikowany : 02/12/2020 2:45 pm
Bob the Maker
(@bob-the-maker)
@aln-perez
Thanks for the reply.
Selecting the COG beside the printer I see the IP address settings but is not finding Octoprint during the search, therefore not connecting.
Opublikowany : 02/12/2020 2:50 pm
Bob the Maker
(@bob-the-maker)
Solved.
Created an Application Key in Ocotoprint and entered the IP and Key information manually into PrusaSlicer/My_Physical Printer Parameters and it connected. I am now able to send files directly.
Can't wait to test the new slicer more.
Thank you Prusa team.
Opublikowany : 02/12/2020 3:24 pm
Posted by: @bob-the-maker
Windows 10
Octoprint 1.5
Is the Octoprint server running and are IP address and api-key correct? On the 2.3.0 alpha4 it works fine. I have not tested Beta1 yet.
Systems:
Lenovo Thinkpad W510 - W10 Pro
Description: Raspbian GNU/Linux 10 (buster)
Kernel: 5.4.51-v7+
Octoprint: 1.4.2
octopi: 0.17.0
Opublikowany : 02/12/2020 4:03 pm
