PrusaSlicer 2.3 Beta Octoprint connection
I am having trouble connecting to Octoprint. I have added a physical printer but it will not find the server in network search. I have tried adding the IP address and API info but fails to connect. Is anyone else having this problem?
Windows 10
Octoprint 1.5
RE: PrusaSlicer 2.3 Beta Octoprint connection
Click on printers parameters... Now IP server is moved here.
MK3S + MMU2 migrée vers une MK4 +MMU3 , puis vers MK4S MMU3, puis upgrade vers Core One, Elegoo Mars, bricole sur Home assistant, arduino, 8266, Esp32, kicad, Freecad et Fusion 360
@aln-perez
Thanks for the reply.
Selecting the COG beside the printer I see the IP address settings but is not finding Octoprint during the search, therefore not connecting.
Solved.
Created an Application Key in Ocotoprint and entered the IP and Key information manually into PrusaSlicer/My_Physical Printer Parameters and it connected. I am now able to send files directly.
Can't wait to test the new slicer more.
Thank you Prusa team.
Windows 10
Octoprint 1.5
Is the Octoprint server running and are IP address and api-key correct? On the 2.3.0 alpha4 it works fine. I have not tested Beta1 yet.
Systems:
Lenovo Thinkpad W510 - W10 Pro
Description: Raspbian GNU/Linux 10 (buster)
Kernel: 5.4.51-v7+
Octoprint: 1.4.2
octopi: 0.17.0
