PrusaSlicer 2.3 adds gaps between outer and inner wall
foxylion
(@foxylion)
I'm facing currently issues in printing a cookie cutter without any gaps between walls.
When I try to slice the file in PrusaSlicer it generates multiple small gaps between the walls at peaks of the shape.
This is my STL file: https://1drv.ms/u/s!AqQE0B3ZGpOcitsyNUPbd6ILadLFGw?e=4jgzPp
This is my slicer config: https://gist.github.com/foxylion/77bb44578fd8f5db4d8e00f683000fdc
Screenshot:
Has anyone an idea what is causing this problem?
Another thing is experienced is that when I enable "detect thin walls" it will generate some extrusions only on some layers, which will will make the cutter look pretty strange.
Screenhot:
Screenshot of the whole model:
Thank you for your help! 🙂
Best,
Jakob
Veröffentlicht : 26/02/2021 3:59 pm
