PrusaSlicer 2.2.0-rc4
Jakub Dolezal
(@jakub-dolezal)
Mitglied Admin
Hi guys,
a fourth release candidate of the PrusaSlicer 2.2.0 is out, introducing improvement and bugfixes. This version is recommended to experienced users.
What is new?
This is a fourth release candidate of PrusaSlicer 2.2.0, following releases of 2.2.0-rc32.2.0-rc22.2.0-rc2.2.0-beta2.2.0-alpha4, non-public 2.2.0-alpha3, alpha2 and alpha1. This release candidate fixes bugs found in the previous release candidate. See the respective changelogs of the previous releases for all the new features, improvements and bugfixes in the 2.2.0 series.
Improvements with respect to PrusaSlicer 2.2.0-rc3
  • A new "Draft shield" option has been added to produce a skirt as high as the highest printed object. (#2675)
  • Free camera rotation is no more forced for a regular mouse when a 3DConnexion device is plugged in. If the camera up vector does not point up because the camera was rotated with the 3DConnexion mouse, the camera is newly aligned with the screen Y-axis abruptly when touching the regular mouse and a constrained camera rotation mode is active. (#3816)
  • Thumbnails for BIBO and LulzBot printers were added to the installation wizard. We changed the location of these thumbnails, they are newly stored inside the resources/profiles/VENDOR_NAME/ directory, and they should be named by the printer_model identifier suffixed with "_thumbnail.png".
  • The plus button to add a new layer range modifier newly grays out if is not possible to insert a new layer range and the tooltip explains why.
  • Updates to BIBO printe profiles by @photodude.
  • Brazilian Portugese dictionaries updated, thanks @BoaImpressao3D.
Bugs fixed with respect to PrusaSlicer 2.2.0-rc3
  • Full fan speed for G-code visualization was not shown as 100%, fix provided by @rongith. (#2922)
  • Eject of a removable media did not handle fails properly. A message box is newly shown if eject fails.
  • Windows specific: Detection of a 3DConnexion mouse has been refactored to not poll every 2 seconds, but to react to operating system notifications. This should resolve some peculiar freezes of the user interface. (#3424#3515)
  • Windows specific: Detection of external drives (SD cards, USB flash drives) newly reacts to operating system notifications, so it should react faster. Still some attach/detach events are not reported by Windows, therefore the disk devices are still enumerated every 2 seconds.
  • Windows specific: The slicing service pops up error messages asynchronously. If a pop-up menu was tracked at the time the background service popped up the error message, the PrusaSlicer application was stuck. The error dialog is newly delayed until the pop-up menu closes. (#3660)
  • Opening the File menu hang on enumerating the removable drives to update the "Eject" menu item. Also due to a bug in the wxWidgets UI library, the same happened when opening the "Extruders" submenu of an object pop-up menu. This issue has bee resolved by relying on the last known state instead of blocking. (#3279)
  • The Wizard checkbox text "Remove user profiles - install from scratch" was changed to just "Remove user profiles" to indicate that this checkbox does nothing to system profiles. (#3761)
  • Fixed a vase mode issue, where the infill layers were not recalculated correctly after the number of bottom layers was changed. (#3823)
  • Removed a spurious "Unable to enumerate HID devices" console message indicating that no HID USB device was detected, which is likely fine. (#3828)
  • Fixed mouse handling issue at the object list, which was a regression issue from PrusaSlicer 2.2.0-rc3 introduced when trying to fix #3802. (#3830#3841)
  • Fixed wizard issues regarding upgrade from PrusaSlicer 2.1.1 to 2.2.0: Most system presets were renamed for PrusaSlicer 2.2.0 by adding the "@" character to separate logical name from the full name of the profile, and this was not being taken into account by the installation wizard correctly. (#3835)
  • Fixed installation wizard to always install at least one Filament or SLA material compatible with an installed printer model.
  • The Prusa system profiles "Generic PETG" and "Prusa PETG" are now marked as renamed from "Generic PET" resp. "Prusa PET", so that when opening an old 3MF file, links to these system profiles are not lost.
Supported printers:
  • Original Prusa i3 MK3S MMU2S
  • Original Prusa i3 MK3 MMU2
  • Original Prusa i3 MK2.5S MMU2S
  • Original Prusa i3 MK2.5 MMU2
  • Original Prusa i3 MK2/S MMU1
  • Original Prusa SL1
  • Original Prusa MINI
Download link:
https://github.com/prusa3d/PrusaSlicer/releases/tag/version_2.2.0-rc4
Please report any bug here:
github.com/prusa3d/PrusaSlicer/issues
We look forward to your feedback!
Dieses Thema wurde geändert Vor 6 years von Jakub Dolezal
Assembly manuals
/ Knowledge Base
Veröffentlicht : 17/03/2020 9:03 am
Chocki
(@chocki)
RE: PrusaSlicer 2.2.0-rc4
Ermm, Your download link is still to RC3 😀
Veröffentlicht : 17/03/2020 9:21 am
jweaver
(@jweaver)
Link is to RC3 not RC4.. It should be
Veröffentlicht : 19/03/2020 4:30 pm
ben_r_
(@ben_r_)
Is there a date set for the final release?
If at first you don't succeed, redefine success!
Veröffentlicht : 19/03/2020 6:38 pm
Sembazuru
(@sembazuru)
BTW, RC5 is already out: https://github.com/prusa3d/PrusaSlicer/releases/tag/version_2.2.0-rc5
And to see all the releases to access older ones, or what the current latest release is when you read this message, simply go here: https://github.com/prusa3d/PrusaSlicer/releases
See my (limited) designs on:
Veröffentlicht : 20/03/2020 5:12 am
Sembazuru
(@sembazuru)
And two days later 2.2.0 is available on GitHub. https://github.com/prusa3d/PrusaSlicer/releases/tag/version_2.2.0
Hopefully in the next day or two the driver package will be updated with the installer for 2.2.0. Keep an eye out for the drivers and apps package to increase version number from 2.2.9 (this has PrusaSlicer 2.1.1) here: https://www.prusa3d.com/drivers/
Veröffentlicht : 22/03/2020 5:49 am
ben_r_
(@ben_r_)
How come the Announcements section hasnt been updated with RC5 or 2.2.0?!
Veröffentlicht : 22/03/2020 3:19 pm
jweaver
(@jweaver)
Posted by: @benr
2 possibilities of the top of my head
1. Its a weekend?
2. An ongoing global crisis unlike anything we have experienced before
i suspect people might be a little pre-occupied right now?
Veröffentlicht : 22/03/2020 3:26 pm
Sembazuru
(@sembazuru)
Also, historically the announcements came out a day or two after the files were available on github. Give them some time.
Veröffentlicht : 22/03/2020 8:49 pm
Jakub Dolezal
(@jakub-dolezal)
Mitglied Admin
The final release will be published in a few minutes 🙂
Assembly manuals
/ Knowledge Base
Veröffentlicht : 23/03/2020 9:36 am
PPRRUUSSAA
(@pprruussaa)
PrusaSlicer 2.2.0-rc5
Just a question:
How can I change the extruder, which I want to print a Multimaterial from? The drop dowm field is no longer visible.
MacOS 10.15.3 PrusaSlicer 2.2.0-rc5
is this a case for a Github issue?
Veröffentlicht : 23/03/2020 1:39 pm
Hi Unmaker,
are you in Advanced Mode, or Expert Mode?
Veröffentlicht : 23/03/2020 5:25 pm
tj
 tj
(@tj-2)
A small note, the new driver package for windows that includes prusaslicer 2.2.0 is not very nice, it auto reboots by itself without asking and if you click cancel you see the dialog where it asks if you want to reboot or not.
not sure whats going on really but forced auto reboot is not nice at all
Veröffentlicht : 23/03/2020 5:27 pm
PPRRUUSSAA
(@pprruussaa)
in Advanced Mode it is the same as in Expert Mode. The "old" DropDown field is missing ;o|
Veröffentlicht : 23/03/2020 5:29 pm
Lichtjaeger
(@lichtjaeger)
@umaker
Did you try to doubleclick on the color?
Veröffentlicht : 23/03/2020 6:04 pm
Might be a MAC issue as the dropdown is available on Windows 10 with 2.2.0.  I just added a Mk3 with MMU printer via the wizard and I get the selection.
As there have been a lot of changes with regards to the whole vendor functionality as an experiment save a configuration bundle first to back up all your settings and just see if you can add a new MMU printer.  When you have added it select it and see if the extruder option dropdowns become available.
Veröffentlicht : 23/03/2020 8:21 pm
jweaver
(@jweaver)
I just checked mine running under Win7 and I have pull down menus for the Filaments. Looks normal to me, so as Neophyl said, this could be a MAC thing.
Veröffentlicht : 23/03/2020 10:33 pm
Im thinking either a Mac issue or possibly some problem with the existing configuration that the update doesnt like.  By adding a completely new MMU printer and seeing if the dropdowns are there that should rule out if its Mac or a configuration issue.
If its a configuration issue then saving the faulty config, zipping it up and attaching it to the github issue the OP has created would help track it down.
Veröffentlicht : 24/03/2020 7:06 am
Riztnack
(@riztnack)
Any chance we will see a fuzzy skin option?
Veröffentlicht : 29/04/2020 10:57 am
