PrusaSlicer 2.2.0-rc3
Jakub Dolezal
(@jakub-dolezal)
Mitglied Admin
Hi guys,
a third release candidate of the PrusaSlicer 2.2.0 is out, introducing improvement and bugfixes. This version is recommended to experienced users.
What is new?
This is a third release candidate of PrusaSlicer 2.2.0, following releases of 2.2.0-rc22.2.0-rc2.2.0-beta2.2.0-alpha4, non-public 2.2.0-alpha3, alpha2 and alpha1. This release candidate fixes bugs found in the previous release candidate. See the respective change logs of the previous releases for all the new features, improvements and bugfixes in the 2.2.0 series.
Improvements with respect to PrusaSlicer 2.2.0-rc2
  • Basic LulzBot Mini and TAZ6 printer profiles (Aerostruder variants) were added to configuration wizard, thanks @Sembazuru.
  • BIBO2 Touch printer was added to configuration wizard, thanks @photodude.
  • Error messages related to loading vendor-specific config bundles are now more specific to make troubleshooting easier. If you are authoring vendor printer profiles, you should be running PrusaSlicer with --loglevel=trace and you should be watching the console output for error messages.
  • Objects marked as non printable are newly arranged first after all the printable objects are arranged, and the non-printable objects are arranged to separate virtual print beds, so that the printable and non-printable objects are not mixed. (#3790)
  • 'num_extruders' variable is newly available from the output_file_name template.
Bugs fixed with respect to PrusaSlicer 2.2.0-rc2
  • 3Dconnexion settings were not saved between PrusaSlicer sessions on OSX. (#3791)
  • 3DConnexion device zoom speed is now proportional to pressure, while it was fixed before. (#3791)
  • 'Eject SD card / USB Flash Drive' function sometimes took longer than expected to disconnect the device. We improved the eject speed somehow, though especially on OSX the results are inconclusive as it is the operating system, which blocks indeterminately. We now show a wait cursor during eject. (#3795)
  • OSX specific: Internal SD card readers were not recognized by PrusaSlicer and the respective buttons (Export to SD card / Eject SD card) were therefore not shown. (#3793)
  • OSX specific: Text fields in preset pages were sometimes not accepted. This was a regression from PrusaSlicer 2.2.0-beta. (#3797)
  • OSX specific: Fixed crash when creating multiple height range modifiers. (#3727)
  • After deleting a user printer profile, random incompatible Print and Filament profiles were selected. This is a regression from PrusaSlicer 2.2.0-rc. (#3800)
  • After switching a free camera to a constrained camera from the Preferences dialog, the camera Z axis is newly aligned to the screen Y axis. (#3782)
  • Windows-specific: Context menu was sometimes incorrectly popping up after manipulating object selection in the right panel. (#3802)
  • Position of multi-material purging lines on rectangular beds was only correct if the origin was located in the corner of the bed. (#3805)
  • Minor issues in translations were fixed (untranslated strings, typos, etc).
  • Merged Korean language updates from @ulsanether.
Supported printers:
  • Original Prusa i3 MK3S MMU2S
  • Original Prusa i3 MK3 MMU2
  • Original Prusa i3 MK2.5S MMU2S
  • Original Prusa i3 MK2.5 MMU2
  • Original Prusa i3 MK2/S MMU1
  • Original Prusa SL1
  • Original Prusa MINI
Download link:
https://github.com/prusa3d/PrusaSlicer/releases/tag/version_2.2.0-rc3
Please report any bug here:
github.com/prusa3d/PrusaSlicer/issues
We look forward to your feedback!
Assembly manuals
/ Knowledge Base
Veröffentlicht : 13/03/2020 10:10 am
Sembazuru
(@sembazuru)
RE: PrusaSlicer 2.2.0-rc3
Thanx for the attribution for including my Lulzbot profiles. If I make some tweaks, is there a github/gitlab/similar site I can go to submit change requests? I've checked https://github.com/prusa3d/PrusaSlicer-settings and don't see anything to do with Lulzbot in any of the branches. Or is it too early for the Lulzbot vendor to show there yet, and that will eventually be where I could make pull requests?
(FWIW, I don't currently have any tweaks, so I'm just asking for future reference.)
See my (limited) designs on:
Veröffentlicht : 13/03/2020 3:33 pm
vintagepc
(@vintagepc)
Mitglied
Posted by: @sembazuru
https://github.com/prusa3d/PrusaSlicer/tree/master/resources/profiles
Veröffentlicht : 13/03/2020 3:37 pm
Vojtěch Bubník
(@vojtech-bubnik)
Mitglied Admin
@sembazuru
We need to create process for 3rd party profile contributors.
Likely we will create a github organization for PrusaSlicer, where each vendor will have his own github repository for the PrusaSlicer profiles. We did not decide yet.
As of now, you may provide pull requests to PrusaSlicer directly.
Veröffentlicht : 14/03/2020 10:50 am
Sembazuru
(@sembazuru)
Posted by: @bubnikv
@sembazuru
Thanx.
Veröffentlicht : 14/03/2020 5:41 pm
