prusaslicer 2.1, dual material. Can someone explain some of this parameters ?
Strona 1 / 2
marcottt
(@marcottt)
Hi all, trying to move from cura to prusaslicer, i have a delta printer with Y bowden tube to print 2 color. I made some test and it work but some parameter and behavior i do not understand (note i'm note english) so looking for help for tuning change material process.
Explain:
during print, when one color (we say color#1) end the layer and need to change, printer made this movement:
a) go to prime tower (ok)
b) prime some material still #1 (what is this time/mm? need to reduce)
c) retract material #1 some mm (i think about 10)
d) move empty nozzle on prime tower (why? need to reduce to 0 this time)
e) retract material to park position (ok)
f) move slowly material #2 a bit, i think 20mm (what is this time ? i need to change)
g) move with more speed #2 (what is this time ? i need to change)
h) prime material #2 on prime tower (ok)
Can some one tell e about above movement which parameter are involved ?
Also, what is in "purging volume" the "volume unload" parameter ? changed from 70 t0 10 but i do not see change in print...
I see also a problem on layer 1, when color#1 is finish printer change color and print material#2 but di not elevate nozzle so nozzle bump on already printed part with color#1; this appear only for layer1 (it si normal? i tried "avoid crossing perimeter but no result).
Thanks to all, i hope to not be excessive
Marco
Opublikowany : 30/10/2019 11:45 pm
marcottt
(@marcottt)
RE: prusaslicer 2.1, dual material. Can someone explain some of this parameters ?
no one can help me ? also partial answers maybe useful.
thanks
Opublikowany : 02/11/2019 8:39 am
Mechaniker_Legion_5_11
(@mechaniker_legion_5_11)
eror
er2
have problems printing 2 colors
my G code works in Simplify3D, and in PrusaSlicer
completely refuse. what am I doing wrong in a tool change script ????
I use a Y tube and 2 stepper motors.
I like your product and your printers, but unfortunately I live poorly and cannot afford to buy your printer for it as well, MUU2.
G90
G1 X ...xlocation Y ...ylocation F4800; Move X Y for tool change
T[old_tool]; Select Old Tool
G92 E0; Zero Extruder
G91; Relative Coordinates
G1 E-15 F3600; Fast Retract 15mm
G4 P600
G1 E13 F3600; Fast Reinsert 13mm
G4 P1000; Pause 1secs
G1 E-13 F3600; Fast Reinsert 13mm
G1 E-548 F3600; Fast long retract 548+2mm
G90; Absolute Coordinates
T[new_tool]; Select New tool
G1 E548 F3600; Fast insert 548mm
G1 E10 F300; 5mm/s Feed 10
G1 E3 F150; Feed 3mm
G1 E4 F75; Feed 4mm
Opublikowany : 10/11/2019 4:39 pm
I believe Prusa Slicer uses T0, T1, T2, T3, T4   for the five extruders...
Opublikowany : 10/11/2019 5:50 pm
marcottt
(@marcottt)
Later I'll check my change tool scripts
Opublikowany : 11/11/2019 7:00 am
Posted by: @rtyuuu1983
eror
https://1drv.ms/u/s!Ar8zmT5x2zsGhIcdYhmImLBNdpLjXQ
er2
https://1drv.ms/u/s!Ar8zmT5x2zsGhIceeZ3ijqRQm5hnIA
G90
G4 P600
G1 E4 F75; Feed 4mm
Opublikowany : 11/11/2019 12:49 pm
How to write scripts for your slicer? so that he is correct and works for May Marlin.
Opublikowany : 11/11/2019 12:53 pm
@joantabb
my dear interlocutor, give an example of the G-code. it will work without any effort.
For Y pipes through a bolden with two motors and one E3DV6.
If I use Google translator, they may not be accurate in words.
Opublikowany : 11/11/2019 1:01 pm
How to write scripts for your slicer? so that he is correct and works for  Marlin.
Opublikowany : 11/11/2019 1:02 pm
Goog afternoon Rtyuuu,
please find attached a zip fie
this file includes :-
the original 3D model file from autodesk 123D Design,
plus the two STL's - words and background
plus the Prusa Slicer3mf file which holds all of the slicer configuration,
plus the Gcode
this is set up to run on a mk2 printer with MMU1 (bowden feed single E3Dv6 extruder setup)
the mmu1 bowden single E3dv6 configuration is as follows
this means that the two bowden pipes join at the multiplexor  closer than 91.5 mm above the nozzle
if your setup is different you will have to reconfigure the prusa slicer software and re slice the model.
this link may help... https://www.sublimelayers.com/2017/06/first-week-with-prusa-mm-quad-extrusion.html
Attachment removed
Opublikowany : 11/11/2019 3:25 pm
this picture gives you an idea of the prusa multi material setup
Opublikowany : 11/11/2019 3:41 pm
@joantabb
dear thanks I will try how my homemade printer stops printing. And you’ll be sure to turn it off or not. Thanks again. It turns out that you don’t need to write a script, did I understand you correctly?
Opublikowany : 11/11/2019 5:31 pm
Prusa Slicer has a profile for mk2 printer with multi material unit 1, that is a bowden printer
Joan
Opublikowany : 11/11/2019 5:35 pm
marcottt
(@marcottt)
Hi @rtyuuu1983 , sorry for delay.
yes as Joantabb say with prusaslicer 2 there is not a "change tool script"  to use... everything is configured from standard gui
Opublikowany : 12/11/2019 3:48 pm
@joantabb
In general, I set my values and the extruder did not pull out 550 mm of plastic. I don’t understand why such a simple setup does not work?
Opublikowany : 14/11/2019 3:09 pm
@marco-tonoli
what am I doing wrong???
I need to stretch 550 mm (e1) threads and stick in 550 mm (e2)
Opublikowany : 14/11/2019 3:18 pm
People who taste how to solve a problem,
two-color printing in the settings. The problem is that I have a bolden of 550 mm from the multiplexer. And the slicer cuts so that it does not extend this length, but switches immediately from the first to the second stepper motor
Opublikowany : 17/11/2019 5:44 pm
marcottt
(@marcottt)
i'm not sure to understand your situation.
I have a delta printer, with 1 nozzle and a Y splitter and 2 motor, so i have from nozzle to motors:
a) nozzle
b) extruder
c) a short tube to Y (more or less 30mm)
d) y splitter
e) more or less 2 tube about 550mm from splitter to motor extruder.
In this configuration, i put material #2 a 150mm from nozzle, material #1 to nozzle ready for print and launch print.
i have this config:
Opublikowany : 18/11/2019 2:57 pm
marcottt
(@marcottt)
and this (only 1 file i can insert ?)
@marco-tonoli
thanks for the config, I'll try unsubscribe
Opublikowany : 20/11/2019 11:14 am
Strona 1 / 2
