PrusaSlicer 2.0.0 - FINAL
Jakub Dolezal
(@jakub-dolezal)
Member Admin
Hi guys,
let me introduce our newest slicing software PrusaSlicer (formerly known as Slic3r Prusa Edition or Slic3r PE), which is our own in-house developed slicer software based on the open-source project Slic3r. It's open-source and you can get it in our Drivers & Apps Package. PrusaSlicer is a feature-rich, frequently updated tool that contains everything you need to export the perfect print files for your Original Prusa 3D printer.
PrusaSlicer is available for Windows, Mac and Linux
What is new?
This is the final release of PrusaSlicer 2.0.0, mostly fixing bugs discovered in the first two release candidates. The PrusaSlicer 2.0.0 is a successor of the Slic3r Prusa Edition 1.42.0-beta2.
See the project web prusa3d.com/prusaslicer for details.
Bugs fixed
  • Fixed an issue in copy / paste of objects, where if such a situation was stored into a 3MF or AMF project and reloaded, the copied object instance was shifted by half the bounding box size.
  • OSX specific: Fixed a regression issue against the rc2, where it was not possible to delete the last digit in a spin control.
  • Fixed asserts on application initialization #2272 thanks @wavexx.
  • Fixed an error, when setting the support material distance to "0 (soluble)" or "0.2 (default) and the active language was not English #2278.
  • Fixed a crash when setting the infill to 100% and the active language was not English #2279.
Supported printers:
  • Original Prusa i3 MK3S MMU2S
  • Original Prusa i3 MK3 MMU2
  • Original Prusa i3 MK2.5S MMU2S
  • Original Prusa i3 MK2.5 MMU2
  • Original Prusa i3 MK2/S MMU1
  • Original Prusa SL1
Download link:
prusa3d.com/drivers/
Please report any bug here:
github.com/prusa3d/PrusaSlicer/issues
We look forward to your feedback!
Assembly manuals
/ Knowledge Base
Napsal : 28/07/2019 11:28 am
RealityFoundry
(@realityfoundry)
RE: PrusaSlicer 2.0.0 - FINAL
Was smooth variable layer height removed in this release? (I can't seem to find it anymore)
Napsal : 05/08/2019 5:26 pm
Lichtjaeger
(@lichtjaeger)
Posted by: john.m72
It's the most right button in the upper toolbox.
Napsal : 05/08/2019 5:32 pm
RealityFoundry
(@realityfoundry)
Ahh, "Layers Editing", I see it now, many thanks!
Napsal : 05/08/2019 6:18 pm
escknx
(@escknx)
Can't find Undo button, or hotkey.
One awkward move and its gone?
Napsal : 08/08/2019 5:33 am
Sembazuru
(@sembazuru)
Posted by: escknx
I guess you haven't seen the many other threads talking about the missing Undo function, and the responses that Undo should be in the next version. (v2.1.0 alpha 0 is tagged (but no install files available) as of 7 days ago, hopefully that means alpha 1 should be available soon as bugs are squashed.)
See my (limited) designs on:
Napsal : 08/08/2019 3:55 pm
1 lidem se líbí
Codeplayer
(@codeplayer-2)
MK2 is supported, but the only one that has no profile to select in the 1st startup wizard? I guess its the same as MK2S? The difference is just cosmetic:
– Polished smooth rods
– 10x LM8UU bearings
– 3x U-bolts for LM8UU mounting
– Misc. fasteners
– PET printed cable holder part
If so, why would it have a separate icon with similar profile just to avoid confusion or why not have the same icon state MK2/S?
This post was modified před 7 years by Codeplayer
Napsal : 11/08/2019 12:33 pm
Dave Avery
(@dave-avery)
2.1 alpha 1 is on github now with a huge list of changes - https://github.com/prusa3d/PrusaSlicer/releases/tag/version_2.1.0-alpha1
Napsal : 11/08/2019 12:40 pm
Juergen Schubert
(@juergen-schubert)
Where do they  have  hidden  the  sequentiell printing Option. Ist there any doc available for the 2.0 release ?
Napsal : 15/08/2019 6:24 pm
