Prusament PETG - problem
For the first time I have tried printing with Prusament PETG, and am very disappointed with the result.
Uses Prusaslicer, and has used the pre-installed PETG profileHas used "Support"
What's wrong with my setup?
Is there a profile for Prusament that is significantly better and that I can download?
Veröffentlicht : 27/01/2022 10:10 pm
RE: Prusament PETG - problem
I am not a pro at all, but you are using a lot of personal settings. I would suggest to go back to the standard Prusament PETG setting and try again. Maybe a first layer test print to confirm that this isn't the issue..
If you are not using a silicon sock over the nozzle, I would highly recommend it. It is a must have when printing with PETG in my opinion.
Veröffentlicht : 28/01/2022 2:39 pm
