Prusa sliser , when slicing, it completely seals the lower and upper layers
sanya19
(@sanya19)
when slicing, it completely seals the lower and upper layers, what could be the problem?in the model itself or in the program?
Napsal : 14/01/2023 4:54 pm
ARU
 ARU
(@aru)
RE: Prusa sliser , when slicing, it completely seals the lower and upper layers
Please attach a zipped file of your 3mf project. Without the model and slicer parameters you won't get a good answer
Napsal : 14/01/2023 4:57 pm
sanya19
(@sanya19)
ok, https://drive.google.com/file/d/1nkPMSmJj2mpW3dF-25m_h7Q3Geh7ZHtv/view?usp=sharing
Napsal : 14/01/2023 5:28 pm
I dont normally click on off site links but I tried it anyway,  your link requires access so is not downloadable.
Please ZIP up the 3mf project file and then attach it to a post here.  You must zip it or the forum will just silently not attach it, with no warning.  So its best to double check it attached as the edit time on posts is only a few minutes.
Napsal : 14/01/2023 11:29 pm
sanya19
(@sanya19)
Untitled v2
Napsal : 15/01/2023 6:58 am
sanya19
(@sanya19)
I think that everything is fine with the model , you put it on either side anyway , the upper and lower layers are solid
Napsal : 15/01/2023 7:00 am
jsw
 jsw
(@jsw)
I've seen this issue occasionally when trying to slice corrupt or improperly edited .stl files.
Did this come from Thingiverse?  Those I remember came from there.
Napsal : 15/01/2023 7:33 am
sanya19
(@sanya19)
no it was created in Autodesk Fusion 360
Napsal : 15/01/2023 7:56 am
sanya19
(@sanya19)
how not to put , fills only the top and bottom
Napsal : 15/01/2023 8:20 am
seems to slice OK For me in Slicer 2.5.0
Napsal : 15/01/2023 9:01 am
sanya19
(@sanya19)
figured it out, reset the printer profile, re-configured the profile and everything is fine
Napsal : 15/01/2023 9:24 am
Glad you got it sorted out by redoing your profile.  There have been a few instances where profiles have got corrupted and settings are set to something even when it doesn't show in the gui as that.  Usually when a setting gets duplicated in a section it doesn't belong in.  If that happens then there's no gui item to view or edit the duplicate, the later 'copy' of the setting in the list is always used and its non editable.
I suspect you somehow had the setting for Slicing Mode set to Close Holes.  Changing it to that gives identical results to your pictures.
Thankfully this type of corruption seem to be rare.  I've only come across it when someone has imported in a profile (such as from a filament manufacturer) that was malformed and had settings from print profiles and printers in the filament section.
Another good reason to regularly do Export config bundles for backups.
Napsal : 15/01/2023 10:40 am
