Prusa Slicer won't open on windows 10, hangs up at "preparing settings tabs..."
crosta21
(@crosta21)
Today I went to open PrusaSlicer 2.3.3 (which was working just fine a few days ago) and now it won't respond. The main run window is stuck at "preparing settings tabs..." and the actual program window pops up but is grayed out and when you click anywhere it says (not responding) My only option is to force close the program. Very frustrating...
I've tried the following:
-run as admin, installed any windows updates, updated graphics drivers, removed and reinstalled PS multiple times, cleared the cache file under appdata at reran, installed an earlier version of PS just to check.
Each thing I try results in the same. This is on a pretty much brand new Alienware PC running windows 10 20H2. I have a Ryzen 9 5900 with Nvidia 3070...
Any help is greatly appreciated.
Thanks
Opublikowany : 20/07/2021 10:34 pm
jweaver
(@jweaver)
Look here
https://forum.prusa3d.com/forum/prusaslicer/ps-2-3-0-takes-about-a-minute-to-launch/#post-437002
Opublikowany : 25/07/2021 9:54 pm
crosta21
(@crosta21)
Still no luck...
I went through that article and tried everything... still hangs up and never opens, Let it spin for 30 minutes just to be sure and never fully loads?
Opublikowany : 29/07/2021 7:52 pm
