Prusa Slicer version 2.4.0 A acceleration question
SailorEric
(@sailoreric)
So, in my years programming CNC cutting equipment in that system if I wanted slower, smoother acceleration I put in larger numbers. It was the steps taken to achieve a defined change in speed. In slicer I'm not sure that is the case, is it the same or the opposite?
Just an old guy learning to better control his equipment, thanks.
Opublikowany : 24/10/2021 5:06 pm
29a
 29a
(@29a)
Acceleration
Since the unit used for the acceleration control sis mm/s^2 I'd expect a bigger number to result in faster acceleration.
Opublikowany : 24/10/2021 6:08 pm
1 ludzie polubili
Values represent actual acceleration (and jerk) rates
Posted by: @sailoreric
The speeds you specify represent mm/s^2, so are the "actual" acceleration factor. Larger values produce more rapid acceleration. Jerk represents the rate of change. Hope that makes sense!
Opublikowany : 24/10/2021 8:16 pm
1 ludzie polubili
SailorEric
(@sailoreric)
Got it
Thanks for the answers. Got it.
Opublikowany : 24/10/2021 11:08 pm
RE: Prusa Slicer version 2.4.0 A acceleration question
As a quick addition:
https://www.3dmakerengineering.com/blogs/3d-printing/velocity-acceleration-jerk-and-junction-deviation
wbr,
Karl
Opublikowany : 25/10/2021 12:48 am
2 ludzie polubili
