Prusa slicer support problem
bryanp
(@bryanp)
Hello everyone,
I am new to 3D printing and the forum.
I just designed and made a keyboard holder, in PrusaSlicer I set supports to Everywhere. But when the print was complete I found most of the internal structure was not supported well. Attach pictures show finished part and supports in second try.
Any Ideas on how to setup better supports?
Thanks,
Bryan
Best Answer by Sembazuru:
Just guessing here, but try turning off "Don't support bridges:"?
If you don't see it, change your mode from Simple to Advanced. (The yellow bar to the left of the setting indicates it is an Advanced setting.)
Opublikowany : 05/03/2020 5:47 pm
Sembazuru
(@sembazuru)
RE: Prusa slicer support problem
See my (limited) designs on:
Opublikowany : 05/03/2020 8:38 pm
bryanp
(@bryanp)
Hello Everyone, This user problem Solved!
Yep new user, I had "don't support bridges" = ON.
Thank You Sembazuru
Thanks to all who looked at my problem,
Bryan
This post was modified 6 years temu 2 times by bryanp
Opublikowany : 05/03/2020 9:58 pm
1 ludzie polubili
Mary Tillios
(@mary-tillios)
I recently had a similar problem, a friend helped me solve it. If you have problems can you write.
Opublikowany : 11/03/2020 2:37 pm
Posted by: @marry_till
Would you mind summarizing here so others can benefit?
Opublikowany : 11/03/2020 3:37 pm
