        Prusa Slicer Suggestion for Improvement - Option for Alignment pins in Cut feature
Suggestion: Option to add alignment pins to cuts.
I use the cut feature to either get large prints to fit on the print bed or so I have to use fewer supports (and have less "ugly" surfaces that I have to spend hours sanding). The issue with cuts is accurate alignment when gluing. I glue things, sometimes they slide as glue dries and I get a ridge or lip around the entire piece. If the cut tool had the option to add alignment pins (male on one side/female on the other or aligned pin holes a'la droid division alignment pins) it could greatly improve ease of gluing the two halves precisely. Could have options to adjust size, depth and placement of the pins.
                            Opublikowany : 27/04/2022 3:45 pm
