Prusa Slicer Soluble Full
RandSchlemiel
(@randschlemiel)
OPXL 5H fw: 6.1.3+7898, ps: 2.9.0. Using .4 nozzles with input shaper.
I have a simple model using the Soluble Full config. I've only made a couple of tweaks to the config with a layer modifier to reduce model speeds where the support meets the model.
I have PETG in Nextruder 1 and PLA in Nextruder 2. The model/support settings are set up that way (screenshot attached).
After the bed heating, and before actual printing, the XL wants to perform a filament unload/load on Nextruder 1. Never had this happen before, so don't know if it's something I accidentally set. My understanding that an in-job filament change had to be placed in custom gcode.
Advice?
Postato : 02/01/2025 11:38 pm
RE: Prusa Slicer Soluble Full
You might have accidentally clicked on the vertical bar in preview and added a color change? Easy to do.
Postato : 03/01/2025 4:05 pm
RandSchlemiel
(@randschlemiel)
You're absolutely right, thanks for the advice. I have essential tremors, so click+dragging the layer tool up/down must've resulted in just a click at layer 1. Yet more things to remember/observe!
Postato : 03/01/2025 4:27 pm
It happens too easily. I've found myself tearing hairs out because it's really hard to spot on the first layer.
Postato : 03/01/2025 4:38 pm
RandSchlemiel
(@randschlemiel)
I was unable to find something like "clear all custom gcode adjustments". The result is I need to scan each layer to see if there is a cross indicating an adjustment. Trying to do this often causes another adjustment to be set. Sounds like maybe an enhancement request.
Postato : 03/01/2025 6:25 pm
