RE: Prusa Slicer Skipping walls
With the information provided you wont get much concrete help. Its impossible to tell from simple pictures. (although I can tell you are using thick bridges which is a mistake lol).
What we need is a copy of your prusa slicer project file. So use File>Save Project as to save a *.3mf from PS. That will contain the model(s) and more importantly ALL the settings you are using as well as any modifiers etc. It allows us to debug things. No project and anything is pure guesswork.
However to attach a file to the forum you MUST zip it up. If its not zipped the forum will just silently not attach it. No warnings, just wont be there when you post.
Save your Model and printer setup, in a project file (.3mf file)
then ZIP Compress the Project file and attach the ZIP File to the next post.
Just for sake of general information, there is nothing wrong with Thick bridges, they are a "very viable" tool in your arsenal, as is thick bridges off, you simply have to learn to discern when on or off is the right choice for your project.
Each has it's benefits.
Be weary of this type of advice.
that was supposed to read, Be leary. thanks word press
Hi Everyone,
I do not know what I changed, but I played with some settings, reloaded the project in the newest version, and now it worked. Thanks for the advice!
philca
