Prusa Slicer shows "something went wrong" on the physical printer tab when using PrusaLink
Chris Young
(@chris-young-2)
Sorry for cross posting but wasn't sure if this should be in the Slicer forum or the PrusaLink.
I have been a long-time Octoprint user.  I have Prusa Slicer set up to send gcode directly to it and can even open the Octoprint UI from within the slicer by going to the physical printers tab.  Works great!
The other day I decided I would give PrusaLink a try.  Using the same pi, I built the image on an SD card and put it in the pi.  Everything works as expected.  Slicer sends gcode to the pi and my MK3 displays the filename, IP address, etc.  But what doesn't work is when I go to the physical printers tab in slicer I get an error  "Something Went Wrong".  Is this a known bug that is being worked on or do I have something misconfigured?  If it was the later, I would be having other issues with prusalink.  The prusalink interface works just fine and I'm able to print files that were uploaded via slicer, control the printer, etc.  Any help would be appreciated.
This topic was modified 1 year temu by Chris Young
Cheers
Chris
Opublikowany : 01/04/2025 6:26 pm
