Prusa Slicer Profile for Raise3D Pro2 dual head printer
Page 2 / 3
Rmeister
(@rmeister)
RE: Prusa Slicer Profile for Raise3D Pro2 dual head printer
Sorry, I don't know why my attachments don't come thru?
Trying again.Raise3D-PRO2-Plus
Posted : 19/02/2022 10:40 pm
izumi5188
(@izumi5188)
If you tried to just upload an .ini file it doesn't accept it. I figured out I could zip file one and do that.
Posted : 20/02/2022 1:28 am
izumi5188
(@izumi5188)
@rmeister your printer code works fine for me. I've added some of your differences from your profile to mine and am running tests again.
I was able to get 305 for each of my nozzles with a little extra room for a 5mm brim and 1 skirt loop 2mm away, but it is literally edge to edge on my WamBam plate.
I tired doing an 'auto color change', but it upon restarting it appears I loose the whole layer or it prints off to the side. I think its a PrusaSlicer problem.  M2000 in general works, but here is what I tried.
G1 E-5 Z+5 X5 Y25 F300
G1 E-100 F300
G92 E0
M2000
I plan to upload my modified profile in the next few days if the little tweaks I'm doing work to my satisfaction.
Posted : 22/02/2022 1:03 am
izumi5188
(@izumi5188)
Okay, I was wrong, I just tried to print a full 305x305 object. with brim and it didn't come out right. Back to to testing bed size.
Posted : 22/02/2022 2:04 am
izumi5188
(@izumi5188)
Okay after more playing 305 is the whole space for each nozzle, with brim and everything else.  I updated my code for this and plate texture for the visual. Until I figure out a way to be able to pull extruder offsets manual the start gcode might get slightly off to everyones individual extruder offsets.
I also hope to get a color change sequence eventually figured out that doesn't seem to either delete a layer or mess with the offsets for 1 single layer, but I give up on Prusa Slicer 2.4.0, might try again on the next official build of the slicer.
RaisePro2_v1.1_2202.02.25_PrusaSlicer_config-izumi5188
Posted : 25/02/2022 9:10 pm
deadlymau5
(@deadlymau5)
Hi Everyone,  just circling back to this topic and hoping there is maybe some changes. I'm running a Print Farm with 5 X Prusa Mk3S+ and 1 Raise3D Pro3. I prefer Prusaslicer, hands down. Anyone know of a fully compatible profile for the Pro3?
Posted : 15/03/2022 5:45 pm
izumi5188
(@izumi5188)
In general, No. Rmeister and I have provided our profiles that we worked on for this thread which was for the Raise Pro2. We used our machine print areas. I would think you should just need to update that along with maybe some G code for your start up and cool down sequences. You will have to figure out all of your filament settings as well.
Posted : 15/03/2022 5:54 pm
Vadforean
(@vadforean)
Hello!
I've been using PrusaSlicer (2.3.3, I think) at home for my Ender 5 Pro with really nice, repeatable results with PETG. At work we have a Raise3D Pro2 that I think is printing considerably worse with their own PETG and their dedicated profiles. I also think ideaMaker has a complicated interface with regard to profiles.
How would I go about testing the profiles you (@izumi5188, @Rmeister) have attached for PrusaSlicer (latest) at work? I'm new in this forum and don't really know where to look. Could you maybe just point me to an instruction on how to add a downloaded printer profile in PrusaSlicer?
Best regards
Posted : 09/05/2022 8:52 am
izumi5188
(@izumi5188)
Hi Vadforean,
You can download our printer profiles and import them. Our profiles basically give you the dimensions, and starting and ending gcode for the Pr02. You would need to tune PETG and any other filament to your printers as well.
Posted : 12/05/2022 1:45 pm
ZombiPach
(@zombipach)
Just wanted to thank those of you that contributed to this thread. I've got a Pro3 and am not enjoying ideamaker vs my time with my MK3 and PrusaSlicer. I'll take a look at what progress you've made and see if I can get it to work.
Posted : 02/06/2022 2:07 am
Boggle
(@boggle)
Anybody have a dual material profiles working for the Pro3 yet? Not sure what start/end code it shares with the Pro2.
Posted : 28/07/2022 11:35 am
SvenPaterson
(@svenpaterson)
Good morning! So thank you very much for you guys providing these profiles - saved me a lot of work. Both the left only profile you, and the dual head profile that @izumi5188,  have provided work great. Weirdly though I get this error message whenever I select or enter into the printer config page on PrusaSlicer (imported profiles into 2.4.2, but just updated to 2.5 and it's still happening). I can clear the message and still access the printer settings, slice, and print models using this config, but unfortunately, there is zero explanation of what input value it is taking issue with...
Posted by: @rmeister
Posted : 08/09/2022 1:42 pm
Jelte
(@jelte)
attachments can only be seen and downloaded when one logs in to the forum!
Posted : 15/12/2022 9:50 am
svarteld
(@svarteld)
Hello,
I'm running the HyperSpeed firmware on a Raise3D Pro2 Plus, that require new hardware settings on the dip switches on the stepper drivers. This means that old previously sliced g-code for the standard firmware will not work anymore.
Anyone modified their Prusa Slicer printer definitions to use the new firmware? The new firmware is built on Klipper, with (rudimentary) input shaping, making corners and ringing come out better than before at the same speed. So, it's worth it.
@izumi5188, @rmeister etc, I would be really grateful for updated printer definitions!
Thanks /Peter
Posted : 05/10/2023 8:02 pm
svarteld
(@svarteld)
Hi again,
Some new info:
IdeaMaker in HyperSpeed mode writes this as the very first entry in the gcode file, and omits it when in normal mode:
M99123 /RKIIyAfrgVn63QgWjcMv3w/DQafsD84EnC8915R6MD0Ipw/VGrHawCYdCJaNwKoDQafsD84EnC8915R6MD/RKIIyAfrgVn63QgWjcMv3w/DQafsD84EnC8915R6MD0Ipw/VGrHawCYdCJaNwKoDQafsD84EnC8915R6M/RKIIyAfrgVn63QgWjcMv3w/DQafsD84EnC8915R6MD0Ipw/VGrHawCYdCJaNwKoDQafsD84EnC8915R6M/RKIIyAfrgVn63QgWjcMv3w/DQafsD84EnC8915R6MD0Ipw/VGrHawCYdCJaNwKoDQafsD84EnC8915R6MD0Ipw/VGrHawCYdCJaNwKoDQafsD84EnC8915R6MD0Ipw/DQafsD84EnC8915R6MD0IpD0Ipw/VGrHawCYdCJaNwKoDQafsD84EnC8915R6MD0Ipw/DQafsD84EnC8915R6MD0IpD0Ipw/VGrHawCYdCJaNwKoDQafsD84EnC8915R6MD0Ipw/DQafsD84EnC8915R6MD0Ip0Ipw/VGrHawCYdCJaNwKoDQafsD84EnC8915R6MD0Ipw/DQafsD84EnC8915R6MD0Ipw
Anyone got a grip on how HyperSpeed works on the gcode level? I'd appreciate some pointers.
/P
Posted : 08/10/2023 4:57 pm
manachne
(@manachne)
Hello everyone,
I recently utilized Izumi's profile on my Raise3D Pro2 printer. However, I encountered an issue I hope someone can assist me with. When using the Prusa Slicer, it estimated a printing time of 12 hours for a particular project. Yet, when I loaded the same Gcode file onto the Pro2 printer, it indicated a staggering 121-hour print time.
Initially, the first layer printed beautifully, but subsequent layers were problematic. The printer was very slow during the second layer, approximately ten times slower than usual, correlating with the extended printing time displayed. Despite this reduced speed, it seems that the same amount of material was extruded during this slow printing phase. Consequently, the material from the second layer failed to adhere properly to the first layer, resulting in what can be described as loose strings connecting at the endpoints.
My idea is that there may be a discrepancy in the unit of speed used between the slicer and the printer. While the slicer calculates speed in cm/s, the printer interprets the same value in mm/s. This could potentially explain the significant disparity in printing time between the two. However, this is just a wild guess.
I'm wondering if anyone else has encountered similar issues or if there are alternative explanations and solutions to this problem.
Thank you, Henning
Posted : 22/03/2024 12:28 pm
fmanteau
(@fmanteau)
Has anyone tested this? Does the files work?
Posted : 30/08/2024 6:50 pm
MackDan
(@mackdan)
1.5 years later... I got a Pro2 used and I'm trying to get Prusa Slicer working to output gcode files. Its been updated for Hyperspeed which means its using Klipper. So in Prusa I choose Klipper as the gcode flavor.
I have printed with both the Left and the right print head.  But I have a few issues and want to see if any of you can give me any help.
I did find a thread on Reddit and just posted a message to IridiumTester. his answers to a few questions seem to indicate he's got it working.
https://www.reddit.com/r/3Dprinting/comments/1fnpylu/work_slack_whatever_you_were_printing_over_the/
I'm looking for help/comments on the following issues
Background: I slice the object in Prusa Slicer and output the Gcode. Sneaker net it over to the printer on a memory stick. Find the file on the USB Stick and "Print". I get a couple warning messages about the mismatch of my sliced file and the printer.
1. The first and most obvious is that I didn't use "ideaMaker to slice and it might not work" (paraphrased). The onboard processor/firmware is looking at the sliced file?, or some hidden data in the sliced file that i don't see and comparing it to a stored piece of info that says its ideaMaker 5.3.2.8640 (sic). I tried copying most of the start up gcode from an ideaMaker gcode file and putting that in my PrusaSlicer start up code. Some of it helped, but its not working for this problem. The first line of the prusa sliced gcode is a comment ; generated by PrusaSlicer 2.9.4 on 2026-01-27 at 21:59:55 UTC.  I tried editing the Prusaslicer gcode and deleting that ; generated by PrusaSlicer 2.9.4 on 2026-01-27 at 21:59:55 UTC or making sure that the;Sliced by ideaMaker 5.3.2.8640, 2025-12-26 10:49:51 UTC-0800;Slicer Version: 5.3.0.8620
;Dimension: 305.000 305.000 300.000 0.400 0.400
Is right up front, no suscess
I tried pasting in the M99123  and all the hex data, but that didn't work either.
2. I don't get a hyper speed ok check mark in the ok to print display on the printer. which is ok, but I thought I had it working for one print, so that the check mark was green. I think? the printer just reads the start up g-code and looked at the comment line ;Printer Type: RAISE3D Pro2 - Hyper Speed ?? But that's not working now.
3. I use M140 S{first_layer_bed_temperature[0]} to heat the bed and it works. That was from my Makergear M3ID startup gcode. It sets the bed to the right temp for the nozzle/filament.
4. I'm also trying to use variables to set the nozzle temps for T0 and T1, but can't seem to get it right, and can't find anything on the internet. Tried using ;M109 S{first_layer_temperature[0]} ; wait for nozzle temp to stabilize. Also from my Makergear M3ID, but that didn't work. [0] would be for the left extruder
Tried using M109 T1 S{temperature_extruder1} but got a not valid variable message. Tried that with S{temperature_extruder[1]} , didn't work another variable message
Know the right variable to use?
5. I've read commments about unpacking the raisepack file  twice to get to the Klipper config file. Tried that with 7zip and WinRaR and both did not work.
6. This comment line solved a warning about the nozzle in the gcode not matching the machine nozzle. FYI;Dimension: 305.000 305.000 300.000 0.400 0.400
But I need to try one or two more things.
7. I copied the ideaMaker gcode file comments for filament and pasted those into the Prusa Slicer Filaments Profile start up gcode like this.
; Filament gcode
;Filament Diameter #1: 1.750
;Filament Compensation #1: 93.000
;Filament Density #1 :1240.000
;Filament Type #1: PLA;
Filament Name #1: Premium PLA 1.75mm
;Filament #1: Raise3d Premium PLA 1.75mm
This line (6th) is the important one. ";Filament Name #1: Premium PLA 1.75mm ".   It needs to match the name of the filament you loaded in the printer exactly (meaning the name you gave it). That elimnates the filament mismatch warning in the print OK screen.
That name convention is different from the Raise3d scheme for filament names in ideaMaker vs filament name in the printer
Posted : 28/01/2026 9:23 am
MackDan
(@mackdan)
8. The printer also sets both print heads to the nozzle temp of the filament I'm using (tried with variables for temp, and also a fixed temp like S205 for PLA).
Posted : 28/01/2026 9:29 am
MackDan
(@mackdan)
Got this fixed. See my other post.
Posted : 03/02/2026 12:50 am
Page 2 / 3
