Prusa Slicer on STL
Tony
 Tony
(@tony-13)
Prusa Slicer on STL
I've never had an issue with Prusa but every time I attempted to print this STL I would get stringing in the same spot. I was printing with a new silk PLA so I thought maybe that was the issue. I first attempted to play around with settings, heating up extruder, slowing down print, etc. but with every print, I had the same issue. I finally switched to the PLA I've used before and I had the same problem in the same exact spot. I took the same file sliced it in CURA defaults and raised Temp and the first attempt print started and is still going (all night) with no flaws so far.
I was wondering if the issue might just have been the Slice path Prusa attempted to use vs. CURA on this particular model. Has anyone else had a similar issue before?
Opublikowany : 03/09/2023 3:07 pm
That looks more like unsupported bridging than stringing - check your part is set flat on the bed.
Opublikowany : 03/09/2023 5:22 pm
