prusa slicer multiple configuration startup
steph breakin
(@steph-breakin)
I own 3 differents  printers and  I want to know if  it  s possible  to start  PrusaSlicer with the config I want
it could be : buttons /dialog box/  menu
for exemple button 1
I3  mk3 /petg/ 0.20 quality
Button 2
FLSUN SR /PLA / 0.15
etc .... you get the drill
I already use  snapshot but it s not  User friendly @ all  and it s bugged  (F.E : I can't add a filament type  with the wizard it goes to the end of the process but when I restart the filament I add is missing)
THanks for your help and suggestion
Stéphane
This topic was modified 4 years temu by steph breakin
Opublikowany : 06/03/2022 9:24 am
RE: prusa slicer multiple configuration startup
Officially no. However you can just use project files. Set up exactly as you want it with your profiles etc. then save the project file. (File>save project as)
Then when you load in the project all the settings are restored, as that’s what project files do.
You could have ‘default mk3’, or default cr10, or whatever you want really.
On the filament you are adding, it’s not likely a bug. Not all filaments are available for all printers. They can be locked to vendor spaces and further restricted by both printer and print profile. For example mmu filaments are actually different to normal filaments and not all are available even for a a Prusa mmu.
Opublikowany : 06/03/2022 10:08 am
Use --load my_config.ini with the command line interface to start with a particular configuration.  If you create several startup shortcuts each can load a different setup.
Opublikowany : 06/03/2022 11:47 am
steph breakin
(@steph-breakin)
@diem
I guess you mean through  the fommowing picture  (sorry it s in french)
thanks  you both for your ideas  I'll try them and I will be back here to let you know which one is the most conveniant for me
cheeers
This post was modified 4 years temu by steph breakin
Opublikowany : 06/03/2022 2:50 pm
