Prusa slicer does not work with Fusion360 anymore
Ckobar
(@ckobar)
Hello, since the latest updates, i can't send files from fusion to the prusa slicer anymore. (if the slicer is not running the first file from fusion will open the slicer and that single part is transferred to the slicer)
But any additional part won't be transferred no longer. ( so i have to export in fusion and than import in prusa, wich is quite annoying)
it seems to be a problem on the Mac.  On a window PC it worked like before.
Anybody else with that issue ? Or better, does someone has a solution. ?
Christian
Publié : 06/10/2024 8:47 am
I just tested it, and I can export additional parts no problem. EDIT: "export" as in send directly from Fusion to Prusaslicer.
Publié : 06/10/2024 10:52 am
RE: Prusa slicer does not work with Fusion360 anymore
There is an open issue regarding this on the PS github.  https://github.com/prusa3d/PrusaSlicer/issues/13415
Publié : 06/10/2024 1:50 pm
Ckobar
(@ckobar)
Oh, there just was an update from fusion. Now it works again.
Publié : 06/10/2024 6:14 pm
jessemarsh
(@jessemarsh)
Hi, this is interesting because over a year later with the latest update to 360 I'm having an even worse problem. Without even trying to send directly to PS, if I save as an STL and then open in PS everything looks fine but the gcode is totally corrupt and it prints a mess. Have any of you had the same problem?
Publié : 28/08/2025 1:44 pm
jessemarsh
(@jessemarsh)
RISPONDI: Prusa slicer does not work with Fusion360 anymore
Update on my previous post: the problem persists using the function "3dPrint" from Fusion 360, but if you use "Export/STL" and then open the file in Prusa Slicer it works fine. Strange bug.
Publié : 29/08/2025 6:59 am
