Prusa Slicer Crashes every single time I run it.
Creatorpult Games
(@creatorpult-games)
This is going to be a bit hyperbolic (only a bit though, it really is every single time), so I apologize in advance but I'm losing my mind.
It never crashes on start or when dealing with config or print settings, but every single time I try to do something related to models it crashes. It doesn't always crash on the same activity but I never ever get to actually finish slicing the model. It does not matter what model I am working with either.
- Loading Projects - check
- Arranging Models - check
- Slicing Models - check
This is causing me no end of trouble. I do 3D printing for my business, and I am literally dead in the water. It was working fine until I reinstalled windows. I have deleted every single thing I can find on the PC that references Prusa and reinstalled about 5 times and it does no good. Not only that but Bambu Slicer which is a fork of Prusa Slicer crashes exactly the same way. Is there a way to completely remove Prusa Slicer from the PC or am I going to have to do a clean Reinstall of Windows? It will be the third time if I do. I have logged a support ticket with Prusa support, but I have no idea what kind of turnaround they will have. I am hoping beyond hope that someone here will know what the F is going on and can help me get back to work.
Thanks, and sorry for the rant,
Chris White
Creatorpult Games
P.S. The error windows gives is:
Faulting application name: prusa-slicer.exe, version: 2.6.0.0, time stamp: 0x64904cd1
Faulting module name: PrusaSlicer.dll, version: 0.0.0.0, time stamp: 0x64904cc7
Exception code: 0xc0000409
Fault offset: 0x000000000275958d
Faulting process id: 0x0x6250
Faulting application start time: 0x0x1D9CED376B9FCB3
Faulting application path: F:\Program Files\Prusa3D\PrusaSlicer\prusa-slicer.exeFaulting
module path: F:\Program Files\Prusa3D\PrusaSlicer\PrusaSlicer.dllReport
Faulting package full name: Faulting package-relative application ID:
Event Id is 1000 which means Windows is clueless.
Postato : 14/08/2023 6:41 pm
