prusa-slicer-console --cut 0.001 --repair --export-stl "filename.stl"
Hello,
i'm trying to use commande line to modify batch .stl files.
On my models, i have surface error at the bottom. I don't want to modify my models (more than 200).
I found that if i cut the bottom with prusa slicer and keep only the top part above 0.001, then repair it, the exported file will be exempt of error surface.
I'm using this command line :
The --cut argument doesn't work (either 0.001 or 0,001). No exported file.
If i'm using prusa-slicer-console --repair --export-stl "filename.stl", it will export the file correctly but on some file, it won't be able to repair.
Could you help me please ?
Baptiste
Napsal : 01/01/2023 3:25 pm
