Prusa Slicer and FLSun QQS problem
Brian
(@brian-11)
I've been using Prusa Slicer with a QQS Pro printer. I've gotten a number of prints to complete successfully but there is an issue that occurs where when I load a print sometimes it displays that it's supposedly a % completed. Most recently 14% complete. The bed heats the nozzle heats it prints a prime line then the nozzle gets driven into the bed as it trys to print some geometry in a non planar fashion off the front edge of the bed.
This has happened several times. Once on a part that had been printing just fine where all I did was rotate the part 180 degrees to get the seam where I wanted it to be on the part then started doing this error. There was nothing changed other than part orientation on the bed. Still fully on the bed only rotated 180.
Im producing a part for a guy that he's paying me to do. I need to have my printer working and Prusa Slicer is the only slicer I have gotten to work with this printer.
If anyone can tell me what is the problem and how it should be solved and do that, that'd be great...
Publié : 12/02/2024 7:40 pm
