prusa slicer 2.6.1 not running any script windows 10 ?
Kesasus
(@kesasus)
I upgraded from 2.6.0 to 2.6.1 and noticed that my post prosessing is not workin any more.
The python script runs fine from command line but not hing happeens fron post prosessin option in the sliser prit setup.
The ini-file has the sript line but it does not work.
What is the issue?
here is the ini-file line:
post_process = "C:\\Users\\kesas\\AppData\\Local\\Programs\\Python\\Python37\\python.exe \"C:\\Users\\kesas\\AppData\\Roaming\\PrusaSlicer\\gcodefix\\testlog.py\""
Does anybody else has the same?
Postato : 23/09/2023 5:03 pm
Kesasus
(@kesasus)
RE: prusa slicer 2.6.1 not running any script windows 10 ?
I tested the script with PrusaSlicer-alpha 2.6.0 and it worked fine.
So there is some issue related to updating to 2.6.1
Any solution for this?
Postato : 24/09/2023 1:06 pm
Kesasus
(@kesasus)
Still no response to this post!
Am I the only person in the Prusa world having this issue?
I testes with 2.6.0 alpha and all worked fine, but not in 2.6.1!!
Postato : 28/09/2023 8:49 am
you would probably be more likely to get a satisfactory response, if you were to go to the Prusa Slicer GIT HUB, where the developers hang out.
This forum is a Peer to Peer forum, with little attention from the developers.
Postato : 28/09/2023 8:59 am
Kesasus
(@kesasus)
Thanks, I just posted an issue.
Postato : 28/09/2023 6:09 pm
