RE: Prusa Slicer 2.6.0 alpha 5 Cut Tool Connectors not working
This is Alpha software, so there will be bugs.
If you can definitely (and consistently) reproduce the problem, then check on Github to see if the issue has already been raised. If not, then document the use case (i.e. how the bug can be clearly reproduced) and add a new issue. PrusaSlicer Github is here.
Cheers,
Tim
Postato : 07/03/2023 7:22 pm
