Prusa slicer 2.5 slicing preview issue
Samppa D
(@samppa-d)
Hi, I have a strange issue with prusa slicer 2.5. When  3 d model is added to the build plate everything is fine,but after slicing the model to print i can see that complete model is filled with infill in preview and estimate time for printing is 7h 30 min? Normally printing this part took about 4h.This exact model was printed previously day before with prusa slicer  without any issues. I just cant find the reason for this problem. Can anyone help?
Here is a link
Publié : 13/03/2023 4:12 pm
RE: Prusa slicer 2.5 slicing preview issue
Please attach your zipped up project file.  File>Save Project As.  This will save a 3mf file.  ZIP it up and attach it here.  It must be zipped or the forum wont accept the file.  It wont give any warning either, so best to check it actually attached immediately given how short the forums edit time is too.
A 3mf from PS is a complete snapshot of ALL the settings.  With it we can slice it exactly the same as you and we can see the preview etc and figure out what setting you have that is causing it hopefully.
My guess though is that you have slicing set to fill holes.  Print Settings>Advanced>Slicing>Slicing Mode.  Should be on regular unless you need one of the special modes.
Publié : 13/03/2023 8:30 pm
Samppa D
(@samppa-d)
Hi.Omg..You nailed it,it was slicing mode set to close holes. I didnt change this setting myself,well now it works thanks to you..Thanks  😎
Publié : 14/03/2023 4:27 pm
Glad it was that simple.  🙂
Publié : 15/03/2023 8:51 am
