Prusa sliceer 2.2.0 elevation ZERO
Hi. Is it possible use elvation zero in order to build the piece directly on the build plate without support? The software foes not accept zero elevation. are there some parameters i don't know? i am using a anycubic photon printer. Thanks.
Postato : 06/09/2020 8:15 pm
RE: Prusa sliceer 2.2.0 elevation ZERO
There has to be some gap between the nozzle and bed in order for filament to extrude. The minimum is set to 0.15mm in firmware. Your 1st level will be printed on the bed without support at whatever height you specify in Print Settings->Layer height->First layer height. This is how you get the textured finish on the 1st layer with the textured sheet.
Postato : 06/09/2020 8:29 pm
Topic starter
answered:
@bobstro
it's a DLP printer not a FDM
Postato : 06/09/2020 8:32 pm
