Prusa slice 2.3 supports problem
jackal21
(@jackal21)
Hi anyone,
i've a big problem with support structure, i compare this slicer with CURA, and i prefer pruse slice, but....
I did this test because o surface on my supports was very bad, so yesterday i compare a PICTURE of layers in Prusa slicer 2.3 and CURA.
same stl setting 0.2mm layer high and 0.2mm Z support distance from piece, i see the prusa slicer don't print a support for last 4 layer, so i've 0.8mm distance from piece....i tried to set 0.1mm layer high, and 0.1mm z distance, but same problem, don't print for 4 layers.....
with Cure, same settings looking sliced picture it don't print only for 1 layer, and it's right.
can anyone help me...i tried some settings, interface, no interface, bridge sincronization with layer high, etc......never changes happened.
Please, can anyone help me?
Best regards
Opublikowany : 06/04/2021 7:06 am
RE: Prusa slice 2.3 supports problem
For questions like this, it helps if you save your project as a .3mf file from Prusaslicer. Simply load the STL into PrusaSlicer, then under File, use Save project to create the 3mf file.
Unfortunately, this forum does not allow the upload of 3mf files, so you'll have to Zip it before you can upload it here.
The 3mf file contains not only the model but also all your settings information, so folks here can take a closer look.
Opublikowany : 06/04/2021 11:29 am
