Problems with PrusaSlicer 2.3.0 Alpha 0
Xayoz
(@xayoz)
So I downloaded the git from https://github.com/prusa3d/PrusaSlicer
Followed the Noob Guide at the end of https://github.com/prusa3d/PrusaSlicer/blob/master/doc/How%20to%20build%20-%20Windows.md
Then I get the attached errors and can't go any further.  What am I doing wrong?
Publié : 08/07/2020 10:40 pm
RE: Problems with PrusaSlicer 2.3.0 Alpha 0
You are better off asking on the github.  Far more people likely to know the answer over there.  I do know that the documents arent kept that up to date and I recall there actually already being several issues already asking about compiling errors.
Publié : 09/07/2020 6:18 am
Xayoz
(@xayoz)
Here is the fix that worked:
Close Visual Studio
Navigate to <your project folder>\build\.vs\PrusaSlicer\v16"
Delete the .suo file
Open Visual Studio and all was well again.
Publié : 09/07/2020 4:52 pm
Xayoz
(@xayoz)
Next issue is after compile, what am I doing wron trying to run it?
I follow the "Debug->Start Debugging or Debug->Start Without debugging PrusaSlicer should start. You're up and running!" instruction and get this...
Publié : 11/07/2020 5:27 pm
Andrew
(@andrew-11)
Did you ever find a solution to this?  I also receive the same error after several attempts.
Publié : 08/08/2020 9:29 pm
Xayoz
(@xayoz)
@andrew-m70
https://3dprint.boards.net/thread/13/prusaslicer-2-alpha-compile-error?page=1&scrollTo=28
Publié : 12/08/2020 5:22 pm
Colin
(@colin-4)
Any solutions?  I followed the above link but I didn't see anything that helped.
Publié : 04/09/2020 3:11 pm
Xayoz
(@xayoz)
the final post, "build solution"
Publié : 04/09/2020 4:14 pm
