Problems with PrusaSlicer 2.3.0 Alpha 0
So I downloaded the git from https://github.com/prusa3d/PrusaSlicer
Followed the Noob Guide at the end of https://github.com/prusa3d/PrusaSlicer/blob/master/doc/How%20to%20build%20-%20Windows.md
Then I get the attached errors and can't go any further. What am I doing wrong?
RE: Problems with PrusaSlicer 2.3.0 Alpha 0
You are better off asking on the github. Far more people likely to know the answer over there. I do know that the documents arent kept that up to date and I recall there actually already being several issues already asking about compiling errors.
Here is the fix that worked:
Close Visual Studio
Navigate to <your project folder>\build\.vs\PrusaSlicer\v16"
Delete the .suo file
Open Visual Studio and all was well again.
Next issue is after compile, what am I doing wron trying to run it?
I follow the "Debug->Start Debugging or Debug->Start Without debugging PrusaSlicer should start. You're up and running!" instruction and get this...
Did you ever find a solution to this? I also receive the same error after several attempts.
@andrew-m70
https://3dprint.boards.net/thread/13/prusaslicer-2-alpha-compile-error?page=1&scrollTo=28
Any solutions? I followed the above link but I didn't see anything that helped.
the final post, "build solution"
