Problems with MVS and Max Speed
Hi all
I changed recently from S3D to Prusaslicer 2.4 for Fast prints i use the MVS ( set to 13mm³) and Max. speed (250mm/s) on my Delta..so speed is no problem.. if i slice a bigger STL it never reaches on of its limits. All speeds are set to 0 min layer time is 5s got at max 7,8mm³ flow and max speed of just 109mm/s . If i set manually for Example the infillspeed to 250 then i dont do it but just because the slicer hits the flow limit....in the moment the autospeed seems buggy for me...
" alt="Speed" />
[url= https://i.ibb.co/SQpYJCx/flow.pn g" target="_blank">https://i.ibb.co/SQpYJCx/flow.pn g"/> [/img][/url]
This topic was modified 4 years temu by Barracuda72
Opublikowany : 07/01/2022 9:52 am
